How To Use Microsoft Office Word Online?
My Office has got corrupted, and I want to open some necessary files in my word. Is there any way to view and make word files online by using Microsoft Office Word online?
Yes, you can use Microsoft Office Word online. You have to follow just a few simple steps, and you will be able to use the word online and also you will be able to access all the files of your system over it.
1.) Search office.live.com, and you will get a window which will ask you to sign in to the Microsoft account. Sign in to the office live by using Microsoft Outlook account.
2.) Your account will sync all your data with Office Live and you will be able to view and make new word files. You can also edit all the files.
In this way, you can use Microsoft word online by signing in with office live.
If your entire Microsoft Office suite is damaged, you can repair it. You don’t need to reinstall it to fix the problem because it has a built-in repair feature to fix any problem. Click “Start,” “Control Panel,” and then “Add or Remove Programs.” Scroll down and select Microsoft Office then click “Change.” On the next screen, select “Repair” then click “Continue” and then follow the instructions.
This should fix all problems you are experiencing with Microsoft Office. Once repair is finished, try running Microsoft Office Word again and see if it works. On the other hand, if you want to try opening your Microsoft Office Word document online, go to Free Office Online Apps and click Microsoft Office Word. This will allow you to open and edit your Microsoft Office Word document online.
But before you can use the online app, you need to have a Microsoft account. Sign up for an account if you don’t have one yet to be able to use Microsoft Office Word Online.
