Jane Ruiz
Posted on - 10/20/2017
Hello experts,
I have teamviewer software and I want to know that how I can connect my PC remotely. Please provide me the procedure to use teamviewer to connect remotely to PC.
Thanks in advance for the help.
How To Use Teamviewer To Connect Remotely To PC?
Follow the steps to get connected your system.
- Purchase the software.
- Run it on your system and get configured.
- Create an account using the software. On this screen you’ll need to give a password to your system.
- Access the e-mail address and open the mail you got from the team viewer and follow the instruction. Setup your team.
- Next is to install the teamviewer at our laptop. Follow the same steps given above.
- Take the control.
- Access your PC remotely.
- Now move files and other stuffs on your PC just using your laptop.
If you need to access your computer at home from a remote location, I guess the best option is to use TeamViewer. It is an application designed for internet-based remote access and support. It allows you to connect to any computer or server that is connected to the internet to control your friend’s computer remotely as if you are sitting right next to it.
To establish a remote session between your computer and your friend’s computer, your friend’s computer should also run TeamViewer. To access your friend’s computer, you need to log in to your TeamViewer account. If you don’t have an account yet, you need to create one. Once you are logged in, you will see a list of computers associated with your account.
If your friend’s computer is listed, just double-click it to begin the remote session. But if it is not listed, you need to enter your friend’s TeamViewer account and password to begin the session. For a complete guide, visit How to Log In Remotely with TeamViewer. To get the latest version, visit TeamViewer for Business and Personal or TeamViewer for Windows.
