How To Use Windows Self-service Password Reset?
How will self-service password reset work? What is the purpose of Windows self-service password reset? How to use it?
Self-service Password Reset helps an end user or an administrator to reset their passwords automatically without inviting anyone for help desk support. This feature makes it easy for a user to not waste much time on resetting a lost password.
To enable this feature, first, it is important to download “Windows Azure” which is a cloud service that activates computing services of Windows operating system. After getting Windows Azure Active Directory, it makes it easy to reset the password whenever the user forgets it. It provides the facility of “User Verification” which is simple to accomplish the process required.
