How To View Task Manager For Windows 7 And What Is The Shortcut Key For It?
In Microsoft Windows, there are different ways how to view or bring up the Windows Task Manager. The easiest is using the keyboard. You can press CTRL + SHIFT + ESC to bring up the Windows Task Manager. Another way is to press CTRL + ALT + DELETE. If you don’t want to use the shortcut keys, you can use the mouse instead.
Right-click the Taskbar and select “Task Manager” from the context menu.
Bring up the Task Manager from the Taskbar
The Microsoft Windows Task Manager is a component of the Microsoft Windows operating system that helps users and administrators manage, track, and troubleshoot tasks. A task is a basic unit of programming which the operating system controls. The Task Manager is included with Windows NT, Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8.x.
Every version of the Microsoft Windows operating system creates minor changes to this utility’s functions and features but you can always bring it up with the same key combinations.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
