eccles jhon
10 points
Posted on - 10/08/2012
Hi, I have a friend, he used to use my system regularly. However, when I check the history, he clears everything. How to track internet history secretly so that I can know what he has been doing for so long?
Good day Eccles Jhon,
That's not possible. Once you clear the history on your computer there's no way you can retrieve it nor you can view it by another way. Maybe you should ask your friend directly. Or may I suggest, block the site that you don't want you to visit by your friend.
Hello Eccles,
If the history is cleared you can still check the Cookies unless it is deleted too. If everything is deleted then there is no way to see the browsing history.
Thanks
Hello Ellecs, If you use windows 7 then there is a good news for you. You can easily restore the deleted history of a program easily. Windows 7 has a feature known as system backup and restore. Simply Search windows for backup and restore program. Open it and restore the system to the time earlier than your friend used your computer. After the restoration process is complete. Your Browser History is also restored with that.
