How To Transfer Big Files Over The Internet?
I want send some data which includes some big files to my friend. How to transfer big files over the internet? Can anyone tell a simple method?
There are several ways to send big files:
1. Through google drive: You need a Gmail id. After you login, go to the google drive and click on “upload” button (top left). You will be able to browse from computer for the file. After the file is uploaded, right click on it and click “share”. Then you can enter the email id of the friend.
2. You can use the link for it: https://www.dropsend.com/ Just click on the “send file” button and you will be able to upload the files to one selected email address.
Notifications
