How to transfer css to xml converter software?
How can I transfer CSS to XML Converter software? I'm running Vista and I need to install this without getting any issues. So kindly please explain in complete details. Thanks a lot!
CSS Parser Component converts CSS files to XML documents or the other way around. This program is useful for editing XML documents is much easier than editing CSS files.
This component works with environments which supports COM. You can download CSS Parser Component here.
For the installation instructions, please reference the information below:
Download and install first : MSXML 4 parser
You need to transfer the dll file to this directory → C:Program FilesXStandardBin
Open and run CMD as administrator and change the directory to where the DLL file is located
Type regsvr32 XCSSParser.dll and hit enter
Allow READ and EXECUTE file permission on this DLL to everyone.
