How To Transfer File From Pc To ipad?
I need to transfer a file from my windows pc to my IPad. Can someone tell me how to transfer file from pc to IPad?
For this, you can use itunes to make it really easy. First, download itunes on your pc. Then connect your IPad to your pc through a USB cable. When you open itunes, you will see your device displayed there. Click it and in the new window, click on apps. See the bottom of the screen to find the “pages” option.
There will be a list of documents displayed. Below the list, there will be an option to “add”. Click it and browse to find your required file and click it. The file will start displaying in the documents list of itunes. Now, go to your device and press synn.
It will be copied to your IPad.
