How to transfer files from mobile to laptop?
I have an important file in my mobile handset but a file is needed to edit. At this moment, how can send the file from mobile to laptop to edit?
There are several ways,
1. Upload file from your cell to a storage site like https://www.dropbox.com/?landing=dbv2 and download it to your Laptop by signing in.
2. Email the file to your in box, like yahoo, msn, Google etc and open it from your Laptop. (Don’t have internet use Bluetooth for file transfer).
1. Buy a Bluetooth device, if your laptop doesn’t have this facility.
2. Put that in the USB of your system.
3. System will detect it and install (don’t have drivers try on Google).
4. After installation of drivers the icon will be at your desktop.
5. Go to Setting off Bluetooth icon and find other device in the range of Bluetooth.
6. You must turn on the other device’s Bluetooth too.
7. Make contact both devices applying similar passwords both side.
8. You will see the mobile device on your computer.
9. Now you can transfer data easily.
If you are using USB cable from your mobile you can connect it to your computer then go to my computer look for the directory folder, like drive C: drive D: then it depends to what your folder name of your mobile then click the folder then look for your data copy or simply just drag the data file by pressing the left click and drag it to your computer or laptop.
If the file you need to edit is stored on your mobile phone and you need to send it to your computer or laptop, you can send it by uploading it from your phone to a cloud storage like Google Drive, Dropbox, Box, and other online storage.
If you have a Google account or Gmail account, using your phone, go to Google Drive and log in to your account. If you have a Dropbox account, go to Dropbox and log in to your account. Once you are logged in, upload the file from your phone to the cloud storage.
Once the file has been uploaded, go to your computer and log in to your cloud storage account. Just download the file to your hard drive and that’s it. Another way is to use your phone’s PC software to transfer the file directly to your computer. You need to connect your phone to your computer using the USB cable. Another alternative is sending it via Bluetooth.
If you have a laptop, turn on the Bluetooth connection on your phone and on your laptop and then perform a pairing. Once the devices are paired, you can then send the file directly from your phone to your computer via Bluetooth connection.
