How To Transfer Files From ipad To Pc?
I am buying a new IPad soon and giving my current one to my sister. But before that, I need to save some of my files onto my computer. How to transfer files from IPad to pc?
For this, you need to follow one out of the following steps:
1. If the files are in the form of pictures of other small sized files, you can upload the files on google drive and then you can open up your ID on your pc and download the files.
2. If the files are bigger, download the software called “anytrans” to your pc. It’s available for free download here:
https://www.imobie.com/anytrans/download.htm
Then, connect the IPad to the pc. The anytrans window will look like this: Click on the “content to pC button” as shown. The following window will open: In the list, the transferrable files in the IPad will be shown. You can select them and select the download location as shown.
Then, click on start transfer. Your files will be transferred.
