madly madly
Posted on - 02/01/2013
Hi Experts,
I want to transfer files from a computer to another computer with full security. I am not very much aware of sky Robo disk, can anyone help in educating me for how to transfer files via sky Robo disk.
How to transfer files on sky Robo disk.
Hi Madly. I suggest you to adopt a simple way to transfer your data from one computer to another. You should connect both PC's by a network cable to attach them, by sharing a first computer's hard drive on the other one.
You have to establish a network connection between these two systems. After this you can easily access the files and folders from one system to another. This is a secured connection as well, as this is locally established. In my opinion you do need any third party software for transferring data.
OK, That's very good. 1st you need to go a sky Robo disk site and also need to create a personal account. You can buy monthly or get free, that as you like. If you would like to send the office document or excel file you can create that with password protect. As that result you will get full security.Â
Thank you.
You can follow a simple process for transferring data from one computer to another by connecting both PCs with a network cable. After doing this, you can easily access the files and folders from one system to another.
This is the best way of connecting. On the other hand, you can create an account on the Sky Robo disk site.
You can either get a free or premium account. For your security, you can password-protect your files.
Enjoy.
Hi. Madly,
What I got from the above statement is that you want to transfer files from a computer to another computer with full security.
Windows Easy Transfer is a new application that comes installed in most new Microsoft Windows operation system. One way to use this program is with an Easy Transfer cable, a special double USB cable.
The cables, that can be bought online and in computer stores, facilitate file transfers between two windows systems and works great for our purposes.
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
