How to transfer huge data from one PC to other
I have bought a new laptop and I would like to transfer all old files in the old laptop to the new laptop. What is the best and easiest way to do it? I do not have a portable hard disk and I do not want to buy only for this reason. The file size is around 400 GB I guess. The old system has windows 7 and the new has Windows 8.1 for you information if it helps. I have heard we can connect via USB or Ethernet but don’t know both the methods; type of cables required and setup information. Thank you for your help.
