How to transfer mp2 drivers to media player easily?
Greetings Techyv members. Please help me how to transfer mp2 drivers to media player easily. What are the steps needed for this kind of configuration? Also, please include a step by step guide for this kind of transfer. A detailed guide and complete overview on this matter would really help. Thank you so much.
Best Answer by Davidson Mudge
Answered By 0 points N/A #153002
Hi Ryan,
    Adding MP2 drivers has three different options which ever option you choose it will install the driver as long as it is detected.
  1. Auto discover- this identifies and adds new devices, if it did not automatically detected it you can look for the discovered tab and double click the device to have the drivers installed automatically.
  2. Composer view- this is using a 3rd party driver.
  3. Interviewer Wizard- this is also using 3rd party driver but goes through a step by step method.
You can click the link here to give you a better overview.
Answered By 0 points N/A #153003
Hi Ryan Abate,
There are several free media players that can support .mp2 that can be downloaded free of charge from the internet.  It’s all up to your taste on the best program that you want to use to play .mp2 files from your computer. Please download a .mp2 player from http://extensions.awdit.com/mp2/
I would prefer vlc media player. It is easy to use and open source. You can get vlc from the following link http://media.software.informer.com/download-media-player-for-mp2/
