How to transfer PDF to word convert files?
How can I convert PDF files into Word files? Do I need to download anything to convert it? If so, what is the best utility software that can convert PDF files to doc files? I need your assistance. Thanks.
Hi ruthmagnuson,
To transfer your PDF format files to Word format you will need to install a PDF to WORD converter on your computer or simply use Adobe acrobat to convert the files.By using acrobat you need to follow this procedure.
If you want you can cut and paste the contents of a PDF file into a Word document,alternatively you can convert a PDF file to a Word document using Adobe Acrobat.
Simply follow these steps
– Click File>>Open
– Navigate to your PDF file and select it
– Click Open
– Your PDF file opens in Acrobat
– Click File>>Export>>Word Document
– Name your new Word file
-Click Save
Note that having exported your PDF to Word will not alter your PDF file which will remain in its original format on your hard drive (unless you decide to delete it)
If you want to convert an entire PDF document into word document while preserving the layout and keeping the illustrations, you need specialized software. The operation is more complex than the transition from Word to PDF and paid ad hoc programs. There are different software solutions. Here we will use Solid Converter, fast and efficient, which can help out in a timely manner through a trial period of 15 days. If this is a common need, it will buy the license. (In his trial, the software converts only the first page of the PDF)
If you have PDF files that you need to convert to the format used by Microsoft Office Word, the easiest and fastest way to convert the files is do it online which doesn’t require installing third-party applications and completely free. There are two formats that you can convert to: DOC (*.doc) and DOCX (*.docx).
The DOC format is the old Microsoft Office Word default saving format used in Microsoft Office 2003. When Microsoft Office 2007 came, the default saving format used in Microsoft Office Word was changed to DOCX. Now, to convert your PDF files to the old DOC format, go to Convert PDF and other documents to Word.
But if you need the output format to be in DOCX, go to Convert your documents to DOCX. Simply upload the files and convert. The converted file can be downloaded immediately after the conversion and no email address is required to download the file.
Notifications
