Previously I had Nokia N8 and recently I purchased iPhone 4S, so I was wondering if there is a way to transfer my contacts from Nokia N8 to iPhone 4S? Any kind of help regarding how to transfer phone book Nokia phone to iPhone would be appreciated.
How to transfer phone book Nokia phone to iPhone?
From Nokia to MS Outlook
Step 1:
You need to Install Nokia PC suite on your machine, if you do not have it already. Also, You need to have MS outlook installed on your computer.
Via Bluetooth or Data Cable Connect your phone to the PC that has the software installed
Step 2:
Go to Sync >> Sync Options.
Now, click on ‘Contacts’ in the left section, and then select the option “Microsoft Outlook”
Click on OK in this window.
Step 3:
Now, click on ‘Sync’ button for contacts in the Ovi application home. You will find this in the lower left corner when you click on the Home Tab or Contacts Tab on your Nokia Ovi Suite. If you want to sync all you data, you can click on ‘Sync All’ option which is shown in the Home tab, or you can click on ‘Contacts’ tab and this same button will change to ‘Sync Contact’ clicking on which you will be able to sync only your contacts.
This synchronizes the contacts from your Nokia with your MS outlook, this will shift the contacts that you got here from your Nokia phone to the contacts list of Outlook.
Exit Nokia PC suite now, also you can safely remove the data cable or disconnect Nokia Phone from Bluetooth connection.
From MS Outlook to iPhone
Step 4:
Connect the Apple iPhone to your computer and launch Apple iTunes software. Click on your iPhone Device on the left of iTunes.
Step 5:
Click on the "Info"
Click on the check box for “Sync Contacts with” and leave the value selected as default i.e. Outlook. Leave the option selected as All Contacts below that.
Step 6:
Click on the Apply button.
iTunes will start syncing your Microsoft Outlook contacts on to your new iPhone and once it gets completed, you can see all your Nokia Phone contacts on your new iPhone.
