How to tune up windows 7 themes using external sources
I have installed a custom theme on my machine. I messed it up and cannot see anything when I launch any explorer window: I have already tried explorer++, but it can't change theme. How can I tune up windows 7 themes using external sources? please help me.
Best Answer by Leslie Mark
Answered By 0 points N/A #195972
Hi there,
I’m confused about your situation. I’m not sure how to manage the theme at such position but you can retrieve from the problem by following steps mentioned as below:
Go to Start Menu & Open Run.
Type ”cmd” in run & Press Enter.
Type in cmd window as below:
Net stop themes
Now you’ll see normal Desktop as clear. But if you want to back your Theme then type as below:
Net start themes
You can also change the theme with Tune Up Utilities. Now reset the explorer from Task Manager.
Please make this question as solved if it solves your problem.
Answered By 0 points N/A #195970
Hi Greg,
If You are having issues with custom themes so you can get themes by using windows 7 themes changer go to setting option then select the appearance mode it will open your theme section and where you can change, update and save your desire theme. Hopefully this information will help you.
Thanks,
Raun Nelson
