Hi all,
How to turn on camera flash Samsung h1? I just bought this Samsung h1 and am still on the process of exploring all the amazing features. I just want to ask on where can I find the setting to turn on the flash in the camera so that I can still take pictures even if its night time.
Take care and have a nice day.
How to turn on camera flash samsung h1?
Hi Jayden Horribol, I searched a solution that may help you solve your problem.
Just follow these steps for you to enable to turn your camera flash on or off or even automatic.
1. On Menu just go to APPS. Scroll it sidewards to see more apps.
2. Now you can see Camera then click it.
3. You are now on the camera apps of your mobile; you can see a lightning like icon. It is on the other side of square icon (shooting mode).
4. It is the flash mode setting icon, click on it and you will see the no flash, flash and even auto option of your flash just click what you want.
Hope this information helps.
You need to fully understand the user view to turn on your flash for camera.
You can concern with user manual which comes with mobile phone to check this feature.
Check this manual to get all the features for your mobile phone.
Smith Thompson
