Hey guys,
I want to ask a question that is how to turn off notifications from Lenovo PC companion. I don't want to connect my smartphone or synchronize it with my PC but still it shows notifications to connect my phone with it again and again. I looked out for all the settings but it does not show any.
How to turn of notifications from PC companion?
Hi Eric, There are two solutions to your problem,
(a) One is to disable the program at start up of windows. This can be done in the options provided during the setup of the companion program or by clicking on the PC companion settings.
(b) Second solution is to uninstall PC companion permanently if your are not interested in that software. Though an unorthodox solution, it will save space and reduce clutter.
