How to turn photos into fractal art using photshop?
How to turn photos into fractal art using Photoshop? Can somebody explain it to me in simple steps? Or are there any programs that can be integrated with Photoshop for generating fractal art?
Turning photos into fractional art using photoshop is easy. Just open the large image on which you will perform fractional art and do follow some simple steps. Here is link from which you will learn the steps:
I hope the link will help you as it contain a real tutorial.
Hi Dennis Azal,
There are some simple steps involved in this matter.
1. Select the size after loading the image file.
2. Select eclipse or any other tool according to your need.
3. Select & set your desired layer size.
4. Duplicate your work using Alt key.
5. Repeat the step as many times as you need.
6. Rotate if necessary.
7. Use free transform command (Command + Shift + Alt + T)
8. Now, duplicate the created folder.
9. Create as many layers as needed using the previous steps.
10. Adjust the hue & saturation.
These are some basic guidelines of turning photos into fractal art.
Above instructions tell you how to photos into fractional art using photoshop. I will give you fractal art plugins for photoshop this will give you much easier to turn photos into fractal art.
ImpressionFX Manager
This plugin filter can applies attractive styles and paint effects to photos and images.
Apophysis
This fractal flame editing program has a graphical user interface. This program can edit fractal art very easily. You can edit the fractal flames directly or through the window.
Ultra Fractal
This tool can create fractal art, which images are done by repeated fractal formula calculations. Using this tool can create fractal art beautifully.
Fantastic solutions, my friends, and thanks. Scott Douglas, I was surprised with your information and also happy to know the easiest way to turn photos into fractal art. You have explained that among the three programs, the one that I like, Ultra Fractal is the best because it is a great way to create my own fractal art and it is very easy to use and yet more capable than any other fractal program. No mathematical calculations required! Thanks to you and to techyv.com for sharing this post.
Notifications
