How to turn on Samsung galaxy ace free gps? I decided to buy a router in my house to have a wireless internet connection for my Samsung galaxy ace mobile phone. When accessing to some social network sites such as facebook, I would like to know how to turn on my gps to display the location every time I post a status.
If you have Samsung Galaxy Ace S5830, here’s how to turn on the GPS or the Global Positioning System. On your phone, tap the menu icon then navigate to “Settings” then “Location and security”. On the next screen, select or check an option:
Use wireless networks – turning this option on will determine your position faster but may lead to an increase in data usage.
Use GPS satellites – turning this option on will allow your device to locate your exact position using satellite-based GPS but this requires a clear view of the sky.
The Samsung Galaxy Ace S5830 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies measuring 112.4 x 59.9 x 11.5 millimeters and weighing 113 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 320 x 480 pixels screen resolution protected with Corning Gorilla Glass featuring TouchWiz UI 3.
It ships with Android 2.3 Gingerbread powered by Qualcomm MSM7227 Snapdragon S1 chipset, 800 MHz ARM 11 processor, and Adreno 200 GPU. It supports microSD expandable up to 32 GB. It runs on 278 MB RAM with 158 MB internal storage. The primary camera supports 5 megapixels with AF and f/2.6 featuring LED flash. It can record video in 480p at 24 fps.
There is no secondary camera. It has 3.5-millimeter jack featuring DNSe sound, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML.
It runs on removable Li-Ion 1350 mAh battery with standby time up to 640 hours on 2G and 420 hours on 3G. Talk time is up to 11 hours on 2G and 6 hours 30 minutes on 3G. It is available in black, white, Hugo Boss Edition, and La Fleur colors.
1....
