How to type Arabic letters in Photoshop 7?
Different versions were released by Adobe for Urdu and Arabic support and these versions are what we call Middle Eastern versions. However, you will still need to install the Urdu Keyboard and Urdu Fonts into your computer.
I recommend you to use Photoshop CS3 or CS4 versions instead of using Photoshop 7 in your computer because options for Arabic letters available on those versions.
I have attached a link which will be helpful to you.
I hope this helps.
Thank you.
I have used adobe before has I look it true I did not expect to have Arabic language has I know adobe CS6 don't have Arabic nor hebew or you can try this go to www.arabic.keyboard.org/Photoshop-Arabic it' a word box to write Arabic words and transfer it to your adobe CS8.
