How can I type an inverted question mark on Microsoft Word 2003?
Can you give me the shortcut keys?
How to Type a Reversed Question Mark
Hi. I have a solution to your problem.
It is absolutely possible to type an inverted question mark.
All you have to do is to use the following key combination. Just note it down.
you have to hold the CTRL + ALT + SHIFT keys , and then press the ? key .
That is you have the combination as ctrl+alt+shift+? = INVERTED QUESTION MARK.
The shortcut key is alt +0191 ( Holding the Alt key type 0191 will insert the symbol of an inverted question mark.)
You can also use Ctrl+alt+shift+? (Holding the Ctrl, alt, shift then ?
Will also insert an inverted question mark)
Hope I was able to help.
