emileekeila
Posted on - 03/15/2013
I accidentally block a site that I usually uses. Can you help me how to unblock sites? Is there have a software of it? Unblock sites software to use? I really need a software for that so that I can start using and surfing which I blocked. Thank you. I’m looking forward with your answers techies.
How to Unblock sites using a software
Hi there,
Try using https:// instead of http:// if this did not work, follow these steps go to internet explorer the go to tools > Options, select Content Tab and then click "Enable" in the Content Advisor section. Click on the Approved Sites tab and then type in the name of the website you want to block (for example, *.nameofthewebsite.com).
Click "Never" to restrict this website, then "Apply" and "OK." You will then be prompted to create a password to protect your setting from changes by another user. And now to unblock a previously blocked website, click on the restricted web address in the Approved Sites tab and then click "Allow" "Apply" and then "OK."
Hope it helps.
