Hi experts
I am an iPhone user. I enjoy using iPhone cause it has an interesting user interface. But last day I deleted a movie from my iPhone accidentally it's a very important movie for me. Is there any way to undelete movies on iphone 4 cause I have iPhone 4. If any please help me.
How to undelete movies on iPhone 4
Hello there Mac,
I am sorry to hear your problem but there's nothing to worry because I am here to help you out. Having your movie installed on your iphone means that you have it saved on your computer from itunes. All you need to do is plug in your phone to your computer, browse your itunes backup and resync your phone to that and there you go your movie is back. Hope this helps.
Waall Mike
Hi!
Here I will provide you with two solutions for your problem:
First solution:
1. Scan your iPhone by choosing the device backup. Choose your device backup wisely.
2. Then, all of the backup files will appeared. Look for any mpeg format.
3. Finally, select the Recover button on top of the menu.
Second solution:
1. Firstly, you should plug-in your iPhone into computer.
2. In order to scan, you should activate the DFU mode.
3. Once you see the desired contents, you can recover that deleted videos from iPhone.
4. Your previously deleted contents will be listed in organized manner.
