Hi Techyv Friends,
I am using RealPlayer on my Windows 7 and recently I disabled the automatic updates of RealPlayer to avoid the pop-up reminder in that. Now I need to have that update, How to undo RealPlayer update, so that I can get the automatic updates.
Alexandra J Good
Hi Alexandra,
To enable your Auto Update Notification, you should try these following steps:
1. Start your RealPlayer Program.
2. Click ‘View’ menu and select ‘Preferences’.
3. Select the ‘General’ tab.
4. Click ‘Settings’ in StartCenter section.
5. Click to check the ‘Enable StartCenter’ checkbox.
6. Click ‘OK’ (StartCenter dialog box).
7. Click ‘OK’ (‘Preferences’ dialog box to save changes).
If the problem still persists, try to check out their website and download the latest version of the program.
I hope this information will help you.
Martine Paul
Hi Alexandra,
To restore the auto update on real player, you need to configure some parameters on the file player. Kindly click the link below to watch the step-by-step video tutorial on how to update real player. Alternatively, please click the 2nd link provided below to read the Real Player frequently asked questions.
How to update Real Player – This link will guide you through the video tutorial on YouTube on how to update real player. It is very educational and informative video tutorial where you can easily identify and understand the process.
Must Read Real Player FAQ’s – This link will guide you through the real player frequently asked questions.
Ware
