alex baker
30 points
Posted on - 02/20/2013
Hi friends,
I am using Windows 7 64Bit as the operating system on my computer. I am using 3 USB Dongle. It was working perfectly but now I am facing problem with it. It suddenly stops working and lost all the signals.
But after some time the signals automatically come back.
I called to network support agent he directed me to uninstall and then re-install the dongle.
I am looking for a way how to uninstall a 3 dongle safely.
Your kind help is appreciated.
How to uninstall a 3 dongle safely
Hey there Baker,
Uninstalling a software in Windows 7 is almost as easy as child play now.
Go to the Start Menu > Control Panel > Remove a Program from your Hardware.
A list of programs installed is displayed on the screen. Select the 3-Dongle software here in the menu and click on install/uninstall on the upper left corner of the list.
A series of Dialog Boxes appear. Click on Next on every box and finally in the last box click on Finish.
Your 3- Dongle is safely removed from the computer. You can also delete any folder of it left in the Program files in the OS directory manually for further safety. Cheers.
