How to uninstall AppGraffiti from faceBook?
How to uninstalled AppGraffiti from facebook. I have already uninstall it from your computer. But, the ads still pop up?
Hy,
You are installed AppGraffiti in your facebook account. Now you want to unsubscribe the feature from AppGraffiti. That’s so easy to uninstall it. If you would like to uninstall AppGraffiti from your computer at first Go to All Programs from your Start Button and then Select AppGraffiti option and then Select “Uninstall AppGraffiti” option. Now you will get a window for uninstall it. Let you finish successfully uninstall it. That’s better to clear your browser cache after uninstall it. I hope your problem will be solved.
If your problem won’t solve then you may contact with facebook support team. I hope they will help you.
I think you didn’t completely uninstall the application from both your computer as well as in your Facebook account and you only did it on your computer. I’ve already tried one of these before and it is a skin or style applied to Facebook. But usually only those users who are also using this application will be able to see the skin you applied to your Facebook account. And if a user who is not using AppGraffiti views your Facebook profile, he or she will not be able to see the layout you applied.
Uninstalling AppGraffiti is very simple and needs to be done in two different locations, first is from your own computer and the second part is directly from your Facebook account. Uninstalling it from your computer is similar to removing any other applications.
When the application has been removed from your computer, the next step is to remove it from your Facebook account. Log-in to your Facebook account then click on the Remove Layout button found on the top right corner of your Facebook account. If you don’t see this anymore, it’s possible that when you uninstall it from your computer it also disabled the layout in your Facebook account.
