Hi to everyone,
How to uninstall Avg accelerator free? I want to change my antivirus and it is not possible to install two anti viruses at the same time. I am using windows 7 starter operating system, share with me the process of uninstalling a software.
Thank you.
How to uninstall avg accelerator free? Antivirus
Hi Shannon!
If you want to uninstall any kind of software from your PC, just follow these simple steps:
1) Click start.
2) Click control panel.
3) Click programs and features a list of software that are installed on your PC will be displayed.
4) Look for AVG and then click it.
5) Then click uninstall.
Now the un-installation process will run and will require you to restart your computer to ensure that the software will be removed from your system.
Done,
I hope it helps.
Hi, you can uninstall this by repair tool. If it is not required you can uninstall any kind of unwanted programs from your system very easily and firstly. This is really easy to remove unwanted applications which we can not install properly from Windows with the option of Add or Remove which is in the control panel. You can follow below to uninstall. You can select a uninstall error repair tool and download it. After downloading please install this uninstall error repair tool scan.
This is totally free. Now click on the scan button and hit in the uninstall button. You will see your problem is solved.
You are using Windows 7. To uninstall a program:
1. Go to Start menu>Control Panel>Programs>Uninstall A Program.
2. A list of programs will appear. Then select a program.
3. Right-click on it and then select uninstall.
You also can uninstall programs using any Uninstaller. Good Uninstallers are IOBit Uninstaller, Perfect Uninstaller etc.
By these ways, you can uninstall not only Avg accelerator but also any software.
And you said that two antivirus in one PC is not possible. But it is possible and arises many problems. So using just one antivirus software is recommended.
