How to uninstall babylon with command?
Hi techyv,
How to uninstall Babylon with command? Is it possible to uninstall software using command prompt?
I want to try uninstalling software manually using cmd program. This is unusual but there are some instances that we have to learn manual than automatic.
I hope you can provide an accurate information.
Hoping for your help. Thanks.
