pwerzado
Posted on - 08/08/2011
How do I uninstall folder guard correctly?
I used folder guard to have some restrictions on some of my files but don't need it anymore.
I tried to remove the program through F8 (Safe Mode) during reboot but the program ask for password which was set by a technician, unfortunately he is not anymore available.
logictor
5 points
How to Uninstall Folder Guard
Hi good day follow these steps to uninstall folder guard correctly,
Go to start menu > Control panel > click Add and Remove Program > find folder guard icon program click on it.
Then click Remove Note: Please read carefully will you removing the program, and after that restart your computer.
Thank you, hope its help Regards; logictor
Tinah
To completely uninstall the folder guard, get best uninstall tool.
Make sure that all the files and folders are closed.
Run the best uninstall tool – click on force uninstall – click ok – click on next – follow the on screen procedure.
Download this software from here
