Hi all experts,
My sister is using Nokia 5800 express music edition mobile, but she doesn't like a default Symbian dictionary. She wanted to use other dictionary instead of a free mobile sis dictionary, can anyone suggest how to uninstall this default app.
How to uninstall free mobile sis dictionary.
There are applications which has its own uninstallation program that you may take advantage of should you need to uninstall it. On mobile devices, you simply delete the application and you are all set. Whenever that failed, you can uninstall a program or application using Windows. Here's how:
Plugged in your Nokia 5800 to your computer using it's data cable.
Click the Start button.
Go to Programs.
Hover your mouse to Programs and point it to the left direction.
Select Control Panel.
Locate your Nokia 5800 drive location.
Double click it to expand all the files saved.
Select the file you wish to remove from your system.
Click Delete or Uninstall.
Confirm the deletion.
