I am using bizagi process modeler 1.6 which is still running on the background after I removed it and found all over the place . I can't delete them all .How can I uninstall manual bizagi process modeler?
How to uninstall manual bizagi process modeler?
If you have tried to uninstall BizAgi Process Modeler from your computer with Programs->Add/Remove Programs and still isn’t uninstalled then open Start->Run and type regedit.exe. You will open registry editor and here you can find all the registry entries of BizAgi Process Modeler in
1.HKEY_CURRENT_USERSoftware
2. HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRuneg ui
3. HKEY_LOCAL_MACHINESoftwareBizAgi Process Modeler
Delete the registry entries.
Then go in My Computer and delete this two folders: C:Program FilesBizAgi Process Modeler and C:Documents and SettingsUSERApplication DataBizAgi Process Modeler.
You can also use some freeware uninstalling program.
Williamson Mellisa
