Hi Experts,
Roxio starter came pre-installed with windows 7 on my laptop. Whereas I have a registered full version of Roxio Creator that I want to install on my laptop. Can anyone help me out how to uninstall Roxio starter from the system.Â
How to uninstall Roxio starter.
Hi James,
This is a very simple process. Click Start, then Control Panel, then Programs. A list of programs installed in your computer will appear. Find the program you want to uninstall (i.e. Roxio Starter in your case), right click on this and select uninstall. Thus you will be able to uninstall the software from your computer. Then restart your computer and install the registered version.
Hi James,
Most computer manufacturers would have pre-installed software on their computers. If you bought the full version of Roxio Creator chances are your computer will still have the pre-installed version as this is part of the whole package. You can just remove the program from the program list on your control panel.
However there are instances that there will be a conflict with the software if you will install the full version with this you can use a clean uninstaller for Roxio.Â
