kjgamboa
Posted on - 08/30/2011
I have lots of downloaded programs on my computer and some of them are not used anymore. I want to delete them so I could have a bigger memory space on my disk drive. Please help me to find a solution on this. Thank you.
How to uninstall unnecessary programs in Windows XP?
You can uninstall your unnecessary program by uninstalling it from All program list and Control panel.
Go to “Start” then press down “Control Panel” now tap down the “Add/Remove Programs” and on the left part tap down the “Add/Remove Windows components”
Unmark the check box of the tools to delete it in the list of the “Components” after you chose the “Details tab” Delete the folders which contains some tools such as the utilities and accessories and so on.
On your preferred program selection, tap “Next” to see the new windows then delete the irrelevant elements.Now authorize the message box by clicking the “Finish” icon.
Hi there,
In reinstalling its unnecessary program has a lot of ways. The answer above is a good solution.
Another way to uninstall it is by using CC.
Recca90
Hi KJgamboa,
So you want to delete some unimportant installed program to your computer, so just follow the simple step on how you could do it:
Go to the start button. Then type "Program and Installation" in the search box.
After giving the result, click on the program that you want to delete.
Right click and choose uninstall
You can choose uninstall or you can delete it by just clicking on the program and then click the delete option that can be found below.
You can do it manually, because you cannot control it then click due to unable shortcut keys.
