How to uninstall wxpython on Mac OS?
Hello!
I need help in uninstalling wxpython 2.8 from my Mac OSX 10.6. My computer is a Mac OSX version 10.6.6., and my Python version is ActiveState Python 2.7.1. Meanwhile, the wxpython’s version is wxpython 2.8., the one that uses Carbon API and is limited to 32-bit arch mode.
I installed the wxpython 2.8-osx-unicode-py2.7 from the wxpython website using their .dmg installer file. Since this package is limited to 32-bit mode, I have to write my applications using “arch-i386” so that I could import wx. With this limitation, I could not import specific packages such as MySQLdb since it is not available in 32-bit mode.
I assume that the best option I have is to uninstall wxpython 2.8 and then install wxpython 2.9. I have heard that the 2.9 version uses Cocoa API which supports both 32-bit and 64-bit modes.
I was hoping you could teach me how I can uninstall my wxpython 2.8 from my Mac OSX.
I would appreciate any form of help. Thank you.
