How to unlink my Google plus profile from blogger?
Hi guys,
I want to unlink Google plus profile from blogger. I tried to do that in settings in blogger dashboard but I did not find any options to do so. And also please tell me will it have any negative impacts o my following. Please let me know the answer and the impact I will have on my blog following.
Answered By 10 points N/A #186155
Google plus profile linked to your blog helps you to publish your blog and fetch and engage readers. Google+ profile increase discoverability enhance communication with other bloggers and readers. This helps you to reflect posts directly from Blogger to your personal space.
But still if you don’t want to people see about your details from your blog you can remove linkage between your blogger account and Google + profile page. There are some of the easy workaround you can try for the purpose:
You can revise your blog back to your Blogger profile by simply clicking “gadget” icon placed in the upper right corner of blog's “dashboard”. Select "Revert back to Blogger."
If you have added the G+ banner code directly to your blog dashboard, just delete that piece of programming, and you are done. This should look something like:
That's where it looks like your G+ Profile code is attached.
If your “Layout” in the dashboard contains gadget titled “About ME”, delete that from there. This will surely work for you.
Hope this information will be your help.
