Hi. A friend sent me a couple of mpeg files compressed with WinRar. The problem is, my friend could not remember the password she used for WinRar. I need someone to show me how to unlock file in extension rar. My desktop is still on Windows XP 64 bit. Thanks.
How to unlock file in extension rar for XP
You can use WinRar Unlocker or other related software available on the internet. Try searching in google or the best way to solve your problem is to find the password because WinRar has a good encryption and the software will take time to unlock it. But if you are patient enough you can download WinRar Unlocker and start manipulating the password. Please note that trial version are not guaranteed for best results.
Hope this helps,
To unlock a file extension for rar in win xp sometimes file extensions may be caused by registry errors but for our solutions we will use a freeware program called Appnimi All-in-one password Unlocker. Once you install the software since it is portable, it will run anywhere without installation . The appnimi all in one password Unlocker continually tries passwords from password until one password works.
