How to unlock an iPad?
Hello Experts,
How to unlock an iPad? I put a password for the auto lock function for my iPad and then suddenly I forgot the number password that I used. I am very worried for I cannot access my phone anymore. If anyone of you knows how to resolve this issue please do give me some solution.
Thank you.
Best Answer by Elgaothy Carl
Answered By 5 points N/A #187662
Hello Markusa,
To unlock your I Pad you need to connect it with the PC you used to sync your device.
After connecting your device with the Computer, first of all is should sync files then it would ask for a new code. Simply Enter the new code which will be used for locking or unlocking your device further.
Its done now.
Answered By 0 points N/A #187663
Hello
Follow the directions given below,
Connect the iPad to your pc
Select iPad in the iTunes sidebar, and then click the Summary tab
Click Check for Update,  iTune tells you if there' a newer version of the iPad software available.
Click Restore and then follow the onscreen instructions to complete the restore process.
Thanks
