How to unlock iPad in another country
My brother sent me a gift of ipad from UK. I want to break its country code to use it. How to unlock ipad country code to use?
You have to follow the process to unlock it.
At first, download and install the iTunes application from the original provider’s website.
Now, use any SIM (specially unregistered) and try to go to iTunes. Hang around for the detection of your model in the site. Then stay connected for approximately 25 seconds.
Close the iTunes and go to iTunes after waiting some moments.
Actually, you don’t need to break or crack the iPad’s country code to use it because there is nothing to break. The phone or the tablet itself is not locked on a certain country or from the country where it is bought whether it was bought from the United States or from the United Kingdom. To use the Apple iPad for the first time in your country, you need to buy a SIM card.
Once you have a SIM card, turn off your iPad then insert it on your Apple iPad. Once done, turn on the device then start the pre-installed web browser on your tablet then visit iTunes Download to download the latest version of iTunes. If you already have iTunes on your tablet, just continue downloading the latest version. The pre-installed iTunes on your Apple iPad is probably an old version that ships with the device.
If you continue using the old version, you may experience errors from time to time. Once downloaded, install the latest iTunes to upgrade the pre-installed one. After that, you can now use your tablet to download music and other stuffs from iTunes.
