How to unlock user files from protected account?
I want to unlock user files using my own account and unlock user files from another account which is password protected using the same computer. I want to know how to unlock user files from protected account?
Best Answer by Smith Thompson
Answered By 25 points N/A #166786
Good Day, Do you mean on how to "lock" or put password on your files so that it cannot be open by others of course without inputting the correct password?
There are a lot of software in the web you can use for that functionality. Like:
  • Easy File Locker
  • File Locker (web-based)
Feel free to visits these sites for more information and for downloads:
Hope this helps.
Answered By 10 points N/A #166788
I think you are asking about how to unlock account that is located on your computer. It is easy you can use a software that can help in this case and you can find the password of the user how is using your computer by simply installing a software the name of the software is roboform and you can search it from the internet.
Smith Thompson.
