Hi everyone I am using windows xp enterprise and I want not know about dll files because I have some other kind of work in this case I have to to remove the registration of my .dll file from my windows so can any help me to tell me how to remove the registration of a .dll file from Window I will be very thankful to you.
How to unregister a dll
If you want to remove the registration of your .dll file from your Windows operating systems you have to follow the major steps which are written below.
1. First, you have to go into your start menu and select run option from here.
2. Now type cmd without any quotation marks in the search box and click on the run button.
3. Now you see a black window will appear its dose page you have to navigate to the exact locations by typing the regsvr32/u filename .dll. I have written filename.dll .It is the name of the file which you are trying to registration from your operating system.
4. Now press enter. When you press the enter button a information dialog box will appear on your screen.and the confirmation window stating "DllUnregisterServer in (filename) succeeded" will be displayed.
