How To Unzip Files On Windows Vista.
Hey. I am working on windows operating system and cannot figure out how to unzip files on windows vista. Is there a built-in feature to do so or do I have to download some software?
Windows XP or Windows Vista comes with a built-in feature to unzip folders, and the process is simple.
METHOD 1
1. To extract a file, open the zipped folder and drag the file to a new place.
2. To extract the entire content, right-click the zipped folder and select Extract.
METHOD 2
1. Open the zipped folder
2. On the left side of the screen, select ‘Extract all files.’
3. In the wizard, that open, click ‘Next.’
4. Choose the directory where you want the files and click ‘Next.’
5. Windows will extract the files to the specified directory.
6. Click ‘Finish’ to close the wizard.
Notifications
