I must admit that I am no expert at dealing with zip folders. I would like someone to take me through the steps of downloading applications contained in zip folders. Please also elaborate on which software you would recommend for unzipping a zipped folder. How do you build the files after you have unzipped the folder?
How to Unzip Folders and Build Files in the Zip Folders
First, go where the zip folder is from your system. Second, using your mouse, point over on the zipped folder, right click. Third, choose Extract All. The next thing that will going to happen is that all the files will be extracted from the Zip file and you will now be able to see those unzipped files. Whatever messages that will appear is self explanatory. Just consider before activating any applications, make sure it is compatible with your system.
