How to update Active Directory Information the easy way?
What’s the easiest way to include new information, such as address and phone number, to Active Directory? Please share with me what has worked for you.
Hello Missy,
The fastest and easiest way to update Active Directory's information is by using a third program like Quest or rDirectory through a web portal. With rDirectory you can easily delegate the updates to the end user's manager or Human resource. The rDirectory can be found on this link http://www.namescape.com/rdirectory.
You can also use the Wisesoft users Active Directory to edit bulky information in excel or even on CSV. The link to get this from is http://www.wisesoft.co.uk/default.aspx. The best way so far to edit information on Active Directory is by filling excel with the user name's information then getting a VB that loads the information into Active Directory via a CSV format. All in all it this depends on what kind of information you want to enter into the Active Directory.
