How to update for Android ICS in Xperia mini pro mobile?
There is a latest update of Xperia mini pro mobile phone for the latest version of Android ICS?
How do I update it to the latest version of Android?
You can easily do it using Pc Companion.
Here is how to do it:
1. Connect your phone to the pc using USB cable. A popup window should appear on your phone, asking you to install Pc Companion on your Computer. Answer "Yes", and install the program.
2. After installing Pc Companion on your computer, and opening the program, a window should appear, telling you that there is a new phone software version available. If it doesn't happen, go to Support Zone, on Pc Companion (on your left)
3. There will appear a window asking you if you want to upgrade your phone's software. Answer yes.
4. Instructions will appear on your computer. Follow them. Don't disconnect your phone from the computer during the whole process.
5. When the upgrading is finished, you can disconnect the phone from the computer. (the Pc Companion will tell you when)
Notifications
