John Abbot
Posted on - 05/24/2013
Recently I have purchased a computer manufactured by Acer model: Veriton 7700GX
It has an in-built feature empowering technology support aspire one which is a very dynamic feature but I am facing problems while updating and downloading utilities for the same.
Also suggest me the add-on utilities for this model.
How to update the application empowering technology support aspire one?
Hi John Abbot,
You may have to go to the control panel and get into the windows update, if you are using a legit operating system after buying the aspire one laptop, the important updates up to the not-so important updates will be flashed through the list concerning on the updates, choose what updates you want to update and click ok, the download or update progress can be monitored on the task bar beside the time on the right side.
