Hello Guys,
How to update avast mail scan Gmail mac? I am using a mac operating system and I want to update my latest antivirus which is avast to check and scan all the changes and my to clean my local disk drives as well as the computer system registry.
I hope you can help me regarding this matter.
Thank you.
How to update avast mail scan Gmail Mac?
I understand that if you want Avast to scan my Gmail then you need to go into Options in Gmail and uncheck "use SSL"and then set Avast to use SSL and then Avast would scan my Gmail instead of Gmail scanning emails.
Hi Mellisa,
               It is nice to use Avast Antivirus. It is easy to use and very good shield protection. It has user friendly tools for computer protection against web browsing and email. It also has the capability to automatically update the virus definition when you connected to the internet. Its automatic update features automatically download the new update files and also install to the computer. It has an email shield application that scans all your incoming emails. Just connect to the internet to update the vast antivirus.
Thanks
