How to update Bios using asus cap file
I want to update Asus Bios.
I download the bios update but there is no Rom file. I find some Pdf and.
Cap File in updates. I have no idea; now tell me what I should do to update my bios.
Also tell me how to use asus cap file.
Thanks
Answered By 0 points N/A #184525
Hello Tay!
For you to be able to update your ASUS BIOS, you need a flash drive and the BIOS update file.
After you download the update file, copy it into your flash drive then restart your computer. Don’t remove your flash drive. As your computer is booting up, press Alt-F2 simultaneously to access the BIOS setup utility. Select the flash drive from the choices and go to the update files then go to the Tools menu using the arrow keys.
You will see the “ASUS EZ Flash” heading and select YES. The system will now compare your current and new BIOS version. Go to the BIOS update file again then press ENTER. There will be a dialog box that will appear confirming about the update. Select YES if you want to continue. The update takes a little while. Your computer will restart automatically after the update. The .cap file will be the one to be read from your flash drive to update your BIOS.
Just make sure that you back up all your files before updating your BIOS.
