Hi Experts,
I am having intelligent lg seven on my desktop.I need to update this software to the latest version.How to update it without reinstalling it.Can this be done accessing control panel.Provide me step by step guidelines.Thanks.
Jaylonomarion
How to update intelligent lg seven in my desktop?
There is always the option to update every software you have on your computer. This is done to improve the functionality, add features, fix bugs and compatibility issues on newer operating systems, and more. Before doing an update on your application, check your system first for any problems.
If you have any disk utility applications on your computer, use it to check your machine for any possible errors. You may also use disk utility applications like PC Tools Performance Toolkit, Norton SystemWorks, and or Norton Utilities.
After checking your machine, launch the application you want to update then look for the update option on its menu. The update button is usually located or usually can be found in the program’s Help menu. Click on the Help menu then select Update. After this, you will see the instructions on your screen. Just follow them until it is finished.
