How to update maxtor manager software
I have already maxtor manager software and I want to updated Maxtor software so that I can have upgraded the application to new version. Please teach me on how to update Maxtor manager software. Thank you.
Hello Mr Dominque,
You can very easily update your Maxtor Manager software. Please follow the steps below :
> Open Maxtor Manager
> Click My Drives panel and select Settings option.
> Click Check for Software Update button. The software update window will open.
> Put a check mark in the Check for Updates Automatically box.
> Click Check Now button.
> An information window will show that an update is available.
> Press Yes and the download will begin.
> When the download is finished it will prompt to install the update.
> Click Yes to install or No to do it later.
You can also check out this video tutorial for better understanding. Hope this helps.
Best regards.
Dear Dominquedustyy,
Maxtor Manager is one of the popular software, and its needs to update for better support. You can update two ways, one you can open my drives panel of you Maxtor Manager and then check Software update in the setting option. Then you can download update your Maxtor Manager,
Other is, you can use OneTouch 4 – Maxtor Software Update,
You can download OneTouch 4 – Maxtor Software Update from here, Download one touch Maxtor Update
After download you can easily update your Maxtor Manager.
Thanks you for asking!
